Creating Parameters Directly under a GeoSet
I have a script that creates String Parameters, and then I have to Cut-And-Paste each one into the appropriate GeoSet that holds fastener points of a variety indicated by the Parameter String. Is there a way to create the parameter directly into the GeoSet without the need for the Cut-And-Paste?
This 'Parameter in the GeoSet' is the format that is used by a piece of Riveting software.
RE: Creating Parameters Directly under a GeoSet
cut and paste within parameters creation macro.
CODE --> catscript
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Add()
hybridBody1.Name = "GENERAL NOTES"
Dim parameters1 As Parameters
Set parameters1 = part1.Parameters
Dim strParam1 As StrParam
Set strParam1 = parameters1.CreateString("", "")
strParam1.Rename "GENERAL TOLERANCES"
strParam1.Value = "ASNA2110"
part1.Update
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Clear
selection1.Add strParam1
selection1.Cut
Dim selection2 As Selection
Set selection2 = partDocument1.Selection
selection2.Clear
selection2.Add hybridBody1
selection2.Paste
Dim selection3 As Selection
Set selection3 = partDocument1.Selection
selection3.Clear
Dim parameters2 As Parameters
Set parameters2 = part1.Parameters
Dim parameterSet1 As ParameterSet
Set parameterSet1 = parameters2.RootParameterSet
selection3.Add parameterSet1
selection3.Delete
End Sub
Hi l3obAero. What company do you work for? We do similar things at my company for a variety of applications.
Triumph Aerostructures, was the old Vought out of Texas. Working on an Airbus project.
