Scrubber Chemical treatment
Hello. I need some help on the chemical adittion to the water of a wet scrubber. The pollutants are H2S, NH3, CH3NH2, (CH3)3N, C2H7N, mercaptanes and tetrahidrotiofenol. I need to determine the amount of reactants that I should add in order to control the odor. I have no experience in the subject and I don't even know which reactants to add. I've done some research but I've found many different options that are confusing. Any help?
RE: Scrubber Chemical treatment
I am very interested in the subject above, any help will be greatly appreciated. Thanks Josefog
Josefog,
Please, detail the flows and compositions of the streams, the equipment design, operating conditions and expected outcomes from the treatment, so i could give you a more objective answer.
I will oversimplify the problem to give you a general idea: your system has at least two main group of components with very distinct behavior: the sulfide/mercaptan/tiofenol and the amonia/amines.
The amomnia and amines are pretty water soluble (except for (CH3)3N and C2H7N) and a slightly acidic media (HCl or H2SO4, pH <5) would give you a high removal efficiency. For ammonia removal alone, only water could be used in the right operating conditions.
The sulfur containing ones are a little more tricky: they aren't very water soluble and their allowed emission limits are lower. They will need a Base/Oxydizer scrubbing system (most commomly used: NaOH/NaOCl).
As you can see, you will need at least two distinct stages for a good treatment, but three would be ideal: acid scrubbing for ammonia/amines removal, basic scrubbing for H2S and mercaptans removal and a Oxydizer (in a basic media) to finish the sulfides treatment. The basic and the oxydizer/base scrubbing could be joined in a single step/equipment, but i would not advise it if you have high amounts of mercaptans and tiofenols (you can form a lot of dissulfides, that are harder to remove).
