Residential Dry Sidewall application
re: Residential Dry Sidewall application
I just heard news about a new Residential Dry Sidewall, and I can't determine what the best use of this sprinkler would be. The obvious use would be for balconies, however I can't imagine an AJH having a problem with using a QR Dry Sidewall in this instance. Of course there might be the case where in an NFPA-13 application with single occupant garages could still be considered part of the dwelling unit, then a Residential Dry Sidewall could be used and possibly beneficial hydraulically. Since creating and listing a new sprinkler is so expensive, I wonder if there is something obvious that I am missing.
Thanks, Joe C.
Thanks, Joe C.
RE: Residential Dry Sidewall application
http://www.tyco-fire.com/index.php?P=detailprod&am...
