ASCE 7-10 wind loads pressure equation 27.4-1
Hi guys,
Does anyone know how to develop equation 27.4-1 which gives the wind pressure (from the wind velocity) ? I think this equation will generate different case depending on GCpi .. I was struggling a bit to find a simple way to develop this equation and apply it as different case .. I would appreciate if anyone can help.
Thanks a lot ..
Thanks a lot ..
RE: ASCE 7-10 wind loads pressure equation 27.4-1
If you want to simplify your analysis, crunch the wind load numbers, and say "the wind load certainly isn't 35 psf on walls, or 20 psf uplift on the roof. I'll design to that!" If that case does govern, and significantly affects your design, refine.
