dn/pn gaskets for inches/class flanges
It is adequate to use gaskets mark with dn/pn on flanges with flanges mark with inches/ pressure class?
RE: dn/pn gaskets for inches/class flanges
Many times, they can be substituted for one another. Other times, they cannot be substituted.
I will appreciate any information
UNTIL you KNOW the service conditions (pressure, fluid properties, temperature, and ratings of the pipe and flanges), you CANNOT specify nor purchase the gaskets that will
(1) fit between the gasket faces of the flanges
and (2) protect the fluid and your customer from the pressurized fluids/gasses/steam/HP air inside the pipe..
You're trying to make wrong spec'ed gaskets (metric/DN to ANSI/inches) "fit" the hole around the pipe.
That's the wrong question. And the wrong answer will kill people in future. Maybe. Or maybe not.
Maybe these gaskets are way too strong, too thick, and too expensive. Maybe they'll melt through in 10 minutes. Or maybe not.
You don't know yet.
