MUTCD Signal Warrant equations for graphs
Does anyone have the equations for the graphs and charts in the US MUTCD? I can't find them anywhere and need them to do precise calculations.
RE: MUTCD Signal Warrant equations for graphs
Yeah that has some of them but it doesn't have the equations specifically for warrant 4 and 9. That is helpful though. I'm really needing it for warrant 4.
DOT seems to imply there aren't any available. http://mutcd.fhwa.dot.gov/knowledge/faqs/faq_part4...
At this point, I would suggest getting the best quality graph you can find and digitize the graphs. I use a very old program called Tracer for this sort of thing. The graph will need to be scrubbed to remove the grid lines within the graph, and you can use pretty much any photo-editing software for that. Tedious, but certainly doable. Seems like you could possibly make a name for yourself if you publish a polynomial fit to those curves.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Alright I will do that! Thanks so much for the help!
