WPS supported by more than one WPQR
Hi
Have any of you heard about if it is defined in any codes or standards whether it is possible to use two WPQR's to support a WPS for small bore tube welding in super duplex provided that all essential parameters in both WPQR's are equal but that each of WPQR's have different wall thicknesses and diameter. The intention is to expand the wall thickness and diameter range in the WPS.
Kjell Gr°nvold
RE: WPS supported by more than one WPQR
Thanks a lot for your advice
br
kjell
Kjell Gr°nvold
