ANTI WELDING SPOTTER
Hi Guys.
What is the best Brand for anti welding spotter in welding stainless steel.
Thank you in advance, have a nice day.
RE: ANTI WELDING SPOTTER
Try the products from:
http://www.weldaid.com/
I also use their wire lube, instead of air tool oil, in my air needle chipper and chisel to
help reduce contamination of the weld.
For cleaning before or after welding?
I was using the water based. But not much effective. I will try the idea of metalfixer. Anyway guys thank you so much for the idea.
