Dimension with Equal Sign on either side
I have received prints from a customer that had equipment designed in Europe. There is a dimension scheme on the page that I have not seen before and can not find a ISO standard that discusses it. It is a linear dimension between to cylindrical features (hole or boss) and on either side of the dimension it has two parallel lines going horizontally. See attached image. My assumption is that it is some kind of parallelism instruction. Could someone please help me understand the meaning.
RE: Dimension with Equal Sign on either side
Could try posting in http://www.eng-tips.com/threadminder.cfm?pid=1103 which may be a more appropriate forum for this type of question.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
XL83NL,
