NX 9 Motion Simulation 3D Contact
thread561-309251: NX Motion Simulation: Joint Limits
Hello, I am using nx9 motion simulation. My model is a cylinder moving through a hole perpendicular to a pipe. There seems to be no consistency as to when the 3D contact will work against the pipe wall on the opposite side of the opening. I am using a slider constraint with a constant velocity translation. Has anybody else had similar issues. Siemens has been no help in either offering classes or providing instructions on these issues.
Thank you
Thank you
RE: NX 9 Motion Simulation 3D Contact
One Workaround would be to use two markers and a sensor with an if-function, that says: if the marker, which is related to the driven cylinder, reaches the Position of another marker (which defines the end position), than the movement stops.
NX10.0.1.4
