Visio 2007 Calendar appoinments - why is shape sheet value showing a decimal for a date?
Hello!
Two questions regarding Visio 2007 shape sheet date and time formats
I was given a task of writing a Visio VBA script that will take a Monthly Calendar shape that
has many appointment shapes within, extract the appointment info, and send an Outlook email
to various people containing message populated with the appointment shape data.
I am confused as to the difference between what I see in the little Shape Data window and
what I see in the Shape sheet. Example: With a calendar appointment shape, the shape data
displays the start time, end time, and date exactly how I would like. The Shape sheet shows
me some odd decimal values of which I have no clue as to what they mean.
My questions are:
1. When trying to extract appointment shape start, end, and day values, do I try to code
in using Cells, CellsSRC, or something else?
2. Can you provide a hint as to how to extract shape data for an email message?
I have attached a PDF picture hopefully clarifying my delimma.
I believe if I can get past this hurdle I should be able to handle the rest of the task.
Thank you
Tom
My questions are:
Thank you
Tom
RE: Visio 2007 Calendar appoinments - why is shape sheet value showing a decimal for a date?
I suggest that you post in Tek-Tips.com, which is more oriented to this type of question.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Thanks for the assistance.
I'm considering having manager start learning how to use MS Outlook for scheduling meetings
rather than starting from Visio ending into Outlook. Seems like a backwards task.
Thanks!
TTFN
