catia getting deactivated
Hi All,
We have an issue here. catia tools ( icons ) are deactivated abruptly.recently we have hosted the licenses in a triad server ( 3 servers). i checked the client machine. it is pinging with the servers properly.any ideas its my job?
RE: catia getting deactivated
if you're using DSLS, then upgrade to R2015x (Version 6.417.2)
Also make sure your license txt file does not have any empty line at the end or space at the end of each line...
you find the location of the text file with command prompt : set DSLS.
Eric N.
Hi itsmyjob,
Thanks for ur quick reply.we use LUM here as of now and are on the way to DSLS.the issue happens only with one client machine.
catia level of this machine is the same as other machine?
Eric N.
lum on clients are at same level?
Eric N.
we have catiav5r18 installed in all the machines.
on the problematic machine, does lum see the server and free license?
Eric N.
yes.it is showing the server. but what do u mean by free license?
available
Eric N.
yeah.free license is available.i suspect it might be a network issue.but unable to figure out specifically.
might be... turn off the computer and wait a bit before you turn it back on so it does get a new connection from server.
did you try with different users on that computer?
Eric N.
yes.the other user is facing the same issue as well.
but LUM on bad computer does see available licenses. strange.
you have any error message when you start CATIA?
Eric N.
I get the common licensing errors when i start CATIA i.e node lock license expired,license not available. we have two catia versions installed in the machines,one is catia 4 tier customised for tc 4 tier and catiav5 r18.the user is supposed to run the 4 tier.
Hi All,
We solved it.the issue was happening with only one user profile (not in both profiles as mentioned).we reset it and now its fine.there are no issues.thanks all.
