NX Part Families Excel Error
Hi All
I have a rather annoying problem, not a show stopper just one that bugs me. Running NX9.0.3.4 MP3 and have been for about a year. Also using Office 2007.
I have a bunch of Part Family master files, the files all work fine. The problem is when I have finished working on the spreadsheet in Excel and choose Add-in Apply values, Save Family or Cancel Excel doe not close. I see spreadsheet exit detected on the NX command bar but Excel stays open. It used to close but now for some odd reason it stays open.
I have uninstalled and reinstalled NX and Office with no result. Any ideas? Is there a setting to leave the spreadsheet open somewhere?
Greg
Greg
Greg
RE: NX Part Families Excel Error
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
To reproduce, for me anyway.
1 - Open a part family master part
2 – Menu, Tools, Part Families
3 - Edit spreadsheet, This will open Excel
4 – In Excel - Addins, Save family
5 - This should close excel you and return you to NX, If dropbox is installed Excel will Hang and there will be a NX program error register in the event viewer
Greg
I had the same problem.
When the dropbox application is running than the excel sheet will not close by itself.
When you exit Dropbox the part family functions and the excel sheet will close by itself
