PMI Hole Call Out in Assembly?
Is it possible to create PMI Hole Callout on a part in a assembly? I am using Hole command with Type threaded hole on my piece part.
I have not the ability to select the feature Threaded hole with method Hole callout. I have my part fully loaded and Exact, selection scope to Entire Assembly.
And when I am using method inferred I can select Threaded hole feature, but I get error message "Annotation Plane definition conflicts with selected geometry".
See attached models. I am using NX9
Thanks in advance
RE: PMI Hole Call Out in Assembly?
Hi, and thanks for your response..
I will try that method.
Thanks / Matsa
