NX 9 - Hole callout leader questions
thread561-377924: NX 9 - Drafting Hole Callouts
I have the same question as above as well as another with how to edit hole callout leaders. In the attached image (R2.1 is for reference), I would like the hole callout to have the leader coming off the THRU instead of the bottom.
When you go to settings>line/arrow>arrow line of any dimension on the bottom there is an option to change the vertical alignment of the leader line but this option is missing in hole callout settings. My current work around is to remove the callout leader and create a note with just 'U' text, point to the hole and then align the 'U' over the U of THRU.
Using NX 9.0.3.4.
Using NX 9.0.3.4.
RE: NX 9 - Hole callout leader questions
1. add the hole callout text as usual. Now, don't add the GDT on the same hole callout window.
2. Use Feature Control Frame(FCF) to add the GDT and place anywhere on the drawing.
3. Then click and drag this GDT text to align it at the bottom of the hole callout text.
Attached is the picture:
Use NX 10
Go to drafting preferences=>dimensions=>text=>hole callout. Under the leader attachment, you can select the leader to be on top, middle or bottom of text.
