step file import scaling problem
I translate two files to step file individually using NX. When these two step file are imported together by using Spinfire viewer, the size of the geometry in one part is scaled and it is much larger than the other one. These two parts are no longer matched. However I imported these two step file into NX to double check, everything is fine and no scale problem.
RE: step file import scaling problem
I assume the other part is in millimeters.
In the spinfire software, there is no place to check what is the unit of the file.
Anybody knows how to fix this problem? Thank you
