Denomination of metric bolts acc. to ANSI / ASME
coming from a purely ISO / metric region and not familiar with the subtleties of metric fasteners in an imperial world, I'm in a project where metric bolts acc. to ANSI / ASME shall be used. Intentionally the heavy (structural) type of bolts. Unfortunately, the proc. dep. has corroded the specification for the bolts to the following:
example:
hexagon head bolt M16x100 A490M
There is no code denomination of required bolt dimensions (e.g. ASME B18.2.6M) nor is there the denomination "HEAVY".
My question:
Will some / any supplier correctly deliver "HEAVY" type of bolts purely due to the specified material (A490M)?
Thank you very much in advance, &
Kind regards
R.
example:
My question:
Kind regards
R.
RE: Denomination of metric bolts acc. to ANSI / ASME
