SCF for plate with hole under pure shear loading
Could some body help on finding the stress concentration factor for plate with hole under pure shear loading.
Krishna.
RE: SCF for plate with hole under pure shear loading
it's 4 isn't it ? ('cause pure shear is equal tension/compression ... so that at the Kt = 3 location for the tension load the compression has a Kt of -1, which'd make it add to the tension.
rb1957 is correct, Kt = 4 for shear of circular hole in an infinite plate (Peterson)
Andries
