How to measure corrosion rate from corrosion Probe
Dear All
I have question regarding to corrosion probe
Is there corrosion rate reading from Cor probe can be monitored in real time monitoring (on stream monitor) or the corrosion rate is only can be measure only form remote digital controller or handheld corrosion monitor, so we must remove corr probe from its place with service valve
Need your response or input badly.
Thank you and best regards,
Zachari Alamsyah
Zachari Alamsyah
RE: How to measure corrosion rate from corrosion Probe
Rohrback (ER) and Permasense (external permanent UT) are the two that I'm familiar with.
http://www2.emersonprocess.com/en-US/brands/roxar/...
Try a little research for yourself on Google.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
