Hole position sketch not updating. What could be wrong?
Hello, when I put a hole in a face, i use the positioning sketch, and I dimension the little yellow xy axes that comes up. However when I click in the dimension and change the value the axes does not move, and neither does the hole. The hole seems to be stuck at the point where I chose the face.
What am I doing wrong?
Thanks a lot in advance for your interest and answers.
RE: Hole position sketch not updating. What could be wrong?
When you put a dimension, you have to pick the point itself, not the axis. Those are sketch origin axis.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
