What type of analysis should I use?
Hello all,
First of all, I am brand new to Abaqus. Today I was able to import my Creo assembly using .stp and created instances for each part in the assembly. I created a material and assigned it to each part of the assembly. Then meshed each part using tet. I believe my next step is to define the constraints.
1. New part must have a fatigue strength appropriate to support a 20kg load TBDmm forward, 40mm up, and 40mm to the side of the front of the part under 6G - 10Hz Sinusoidal excitation for 1,000 Hrs (5% of time * 20,000 Hr. life).
2. New part must survive 1680N overload force applied at location described in requirement #3 in the down direction. This will simulate 95% percentile operator body weight with a 1.5x factor of safety.
Those are the two tests I am attempting to perform. Any and all help is welcomed.
Thank you.
Thank you.
RE: What type of analysis should I use?
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
