Looking for 0-5V output IR temp sensor 0-600C range.
hello,
I am looking for a probe that can spit out 0-5V with respect to temperature in the 0-600C or 0-500C range. Ballpark range, it doesnt have to be exactly that. I posted in another forum about datalogging equipment but I think I got that part covered. I just need the IR probe to be able to pick up temps and spit out the analog signal. Something easily mountable, readily available and not too expensive (under 100 bucks maybe?)
Thank you
Thank you
RE: Looking for 0-5V output IR temp sensor 0-600C range.
http://www.omega.com/subsection/non-contact-infrared-thermocouples.html
Keith Cress
http://www.melexis.com/Infrared-Thermometer-Sensor... less than $20, and comes directly out with serial digital.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
http://www.omega.co.uk/pptst/OS136.html is a little bit higher than your target price but fits your other requirements quite well.
