Prestretching
Prestretching
How to stretch a circular part uniformly? Thank you in advance!
RE: Prestretching
RE: Prestretching
RE: Prestretching
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
RE: Prestretching
RE: Prestretching
When applying displacements/constraints to your periphery node set did you specify two different coordinate systems (cylindrical/global)? ABAQUS doesn't like that, and will give you an error like the one you described.
Good luck,
Dave
RE: Prestretching
Thank you so much for replying. My modeling involves two steps. In step one, I prestretched the part by applying uniform displacement on the periphery nodes in radial direction. In step 2, I wish to fix the prestretched periphery nodes (in all translational degree of freedom) and apply a pressure on it. I propagated step 1 to step 2 and specified the same cylindrical coordinates in both steps but was prompt with the error.
Please help. Thanks in advance!
RE: Prestretching
RE: Prestretching
I hope this helps.
Rob Stupplebeen
OptimalDevice.com
My LinkedIn
