Does impact toughness depend on diameter?
If there were multiple diameters of bar made from the same heat at a mill, would the mill perform a Charpy test on each individual diameter bar or would they just test one representative sample from the entire heat/lot? Meaning would they machine the same size charpy sample from two different diameter bars from the same heat.
RE: Does impact toughness depend on diameter?
In most alloys that I work with if they tested transverse toughness on the largest diameter at midradius then I would believe it.
If this product has been cold worked or heat treated then I would require testing of every size. They were made differently and they will have different properties.
