APDL Batch Results Output
Hello All,
I have a part that I am running with many different load cases, 50 to be exact. I have created 50 different load step files, each containing the different loads. In APDL I am able to use the Solve > From LS Files option to solve all 50 at once. My problem is I am trying to have ANSYS store Reaction Solutions for all 50 cases then output then to either a text or Excel file.
Is there a command or macro or something I could setup to do this? I would also like to output nodal reactions for several nodes based on node number for all 50 cases?
