New Concrete Finish Coming Off - Why?
I am not a concrete expert, but a sub contractor had poured this new floor 6 days ago and now the top finish is coming off in about 6 areas in a 5,000 sf floor. The floor is a 5" thick 4,000 psi mix and the floor has a 12" compacted gravel base, plastic vapor barrier, 2" foam insulation with in-floor heat tubes and #6 wire mesh. The concrete was poured in good weather 70-75 deg partly cloudy no rain. The concrete was placed using a pump truck and finished with a ride on finishing machine. Please see the attached photos.
Is it possible that they worked it to much and dried out the top?
Any options for a repair? This is a shop type of building.
Thanks in advance for any help.
RE: New Concrete Finish Coming Off - Why?
http://www.cement.org/docs/default-source/fc_concr...
This one uses at least one of the same picture of blistering, and also seems concerned about placing concrete over a vapor barrier.
http://www.rcil.ca/pdf/Power%20of%20Concrete%20-%2...
It can be repaired but if there will be abrasive traffic on the floor, it will be a constant maintenance problem. Scabble the surface to a depth of at least 3/4 of an inch or to sound concrete if still friable. Top the floor with an abrasion resistant topping like SikaTop or MasterPlate.
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
It sounds like the sun came out and the wind picked up and it set up quickly and they used some cream and a bit of water in a few spots. Which usually doesn't work out so good.
It seams like there is more of a chance to get a bad finish when you pour on foam insulation.
Thanks for the help.
