Erosion Vs Corrosion
Dear friends ;
I'm wondering if anyone could explain what's the difference between erosion and corrosion in a pipeline ?
I'm wondering also if the erosion occurs when we have two phase fluid or it can occur when we have one phase fluid (
liquid for example ) ?
Thanks a lot !
Regards !
Thanks a lot !
Regards !
RE: Erosion Vs Corrosion
http://gekengineering.com/Downloads/Free_Downloads...
In this article they said in page 38
Erosion - All Liquid Flow
• Described by API Equation 14E
Vc = C (density)1/2
where: Vc = critical flow velocity, ft/sec
density = fluid density in g/cc
C = 100 for long life projects
C = 150 for short life project
C = >200 for peak flows
But Aas I read the API 14 E , they just talk about erosional velocity for liquid / gas mixture
Tends to only occur in lines with particles (dirt) at high valocities. The API 14E equation is widely recognized as being highly conservative and the C factor difficult to evaluate, but goives you some idea of whther it is a problem or not.
Corrosion on the other hand is a chemical reaction between a substance in the fluid and the pipe material which results in the pipe material being essentially dissolved over time. Temperature can have a big effect as well as the concentration of the chemical substance.
This all sounds very basic....
As LittleInch correctly states, erosion by clean fluids rather than slurries, at velocities anywhere nearly economic in piping, is pretty much a figment of imagination rather than a real problem- until you get into very long design lives. If clean fluid erosion were a real problem, most control valve trims or pump impellers wouldn't last a month.
thanks a lot for your replies!
I'd like to add that my fluid stream is DIESEL
