Machining Symbol
Machining Symbol
I've got a machining callout on a drawing that I haven't seen before. Wanted to see if I could get some help.
The callout is "60* T < on 3 1/4" Port Circle".
The * is for degrees.
I'm thinking that this just means total angle but haven't found anything to verify.
RE: Machining Symbol
STF
Probably should be Pitch or something though.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
These are for a burner tip in a fired heater. Also, the port circle is correct as they are machined around the burner tip similar to a bolt circle.
The drawing we do have is from 1978.
The money you paid for our advice is equal to the responsibility we take for our opinions!
Just kidding and you are right, that asking the customer is the BEST answer in many cases.
Don't make their ambiguous notation your problem.
STF
Sadly OP hasn't responded to clarify so we may never know.
