ETAP STAR! (requesting help)
Hi people! i am working on a project that requires me to develop a protection scheme to keep a electrical power system stable! Is there any single line diagram that i can use for my project to practice on? Because i can't seem to find any with all the values or settings labeled out for me to create and it is hard for me to set it on my own because i am not too sure with it.
Thanks! pc1
RE: ETAP STAR! (requesting help)
Hi sysy,
Unfortunately it's difficult to find a single line diagram with all data available. As you can understand you have to set a lot of values in the tabs of the ETAP which are not illustrated in the single line diagram. I believe that it will be more helpful to join your theoretical knowledge with ETAP. If you have a fairly good theoretical background you can implement your project.
Okay noted! thanks again :)
