Coating A36 Steel for corrosion resistance
I am designing a tank that has to be filled with sulfuric acid (7% in water)
The tank will be made with A36 steel sheet 1/8”
Then I need to coat the inner surface of the tank.
Can you recommend a material for the inner coating? I am looking for something that can be applied with a brush. Maybe several layers of it
The tank is 0,40x0,40x5 m – open top
RE: Coating A36 Steel for corrosion resistance
If you must use mild steel, then line the tank with fiberglass (chopped and blown variety). Expensive
What is "chopped and blown variety"?
