Traceability of Steel, Quality of galvanization on chemical composition
I have come across a situation wherein Structural steel to be purchased directly from main manufacturers of steel producer or from dealer with proper traceability of raw material for one of the projects.
The steel is galvanized cold formed steel for supporting Photo-Voltaic modules supporting structure in India. The design governing load is wind and deflection. The design requirement calls for steel material with specific Yield / Ultimate strength/ Elongation.
<o> </o>
First query: how can we ensure the traceability of structural steel in process or after fabrication of steel structure? Is there any AISC/BS/IS code reference guidelines for it?
Second query: If there is difference in chemical composition of fabricated steel (test conducted by client) and Chemical composition mentioned in main manufacturer's supplied Test Certificate(TC) of raw material.Can I say that it is not same material for which manufacturer's material TC provided?
Third query: Is there is any effect of chemical composition galvanization thickness we achieve?
Thanks for the forum to raise my queries.
RG
<o> </o>
RG
RE: Traceability of Steel, Quality of galvanization on chemical composition
