nx9 pattern of holes (c-bores)
Hi Guys,
I was using pattern features of c-bore holes on a link body with blend. first "mother" holes is extending up to cut the blend nicely but the holes from pattern are not doing that... do you know if I may fix that with some options or I need to i.e. do synchronous modeling and delete faces?
see attached.
Link
thanks
K.
RE: nx9 pattern of holes (c-bores)
that works thanks
