Bringing 3-phase 120/208V service to existing 1-phase 120/240V facility
An existing 2-storey multi-unit residential facility built in 1980 has 400A, 1-phase, 120/240V electrical service. It is intended to upgrade the existing service to 3-phase, 120/208V, 600A, electrical service, to accommodate an addition of new 3-phase, 208V elevator in the building.
I understand, that we may need to verify if any existing high-energy, 1-phase equipment such as air handling units, HRVs, cloth dryers, kitchen range, etc., are compatible with 208V with a 208/240V listing, prior to considering the upgrade. Is it practical to install a 208V to 120/240V buck boost transformer to make the electrical service compatible with the existing 240V equipment?
Some equipment may take time to work upto intended standards, such as the kitchen range may take longer to heat up or cloth dryer may take longer to dry clothes, etc. But my concern is the damage to the equipment and general safety of using a 208V service to serve loads rated for 240V.
I'd appreciate your comments on the above issue.
Thank you.
Thank you.
RE: Bringing 3-phase 120/208V service to existing 1-phase 120/240V facility
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Why don't you just add a standard wild-leg to support only the elevator instead of slowing everyone's water heaters, ovens, and stoves down?
Keith Cress
