ASME Section VIII, Div. 1 Appendix 13
Does anyone have an acceptable nozzle reinforcement calculation method for Appendix 13 box headers, where the nozzle inside diameter exceeds one-half of the header inside width?
RE: ASME Section VIII, Div. 1 Appendix 13
sidneyj (Chemical)
Attach is the British Engineering Technical Report 1981 Viol XIV Non - Circular Pressure Vessels Some Guidance notes for designer page 62 to 88 from the following web site.
http://www.gowelding.com/square.pdf
Also, NOZZLE PRO / FE-PIPE by Paulin Research Group
11211 Richmond Avenue
Suite 109,
Houston, Texas 77082.
Phone:    281-920-9775, FAX:281-920-9739
http://www.paulin.com
E-Mail: tony@paulin.com
Leonard@thill.biz
www.thill.biz
