Deflection of Timber Floor Joist
I designed floor joists for a commercial office. Joists span 6m but most are supported on interior walls, but I designed the joists for a simple span of 6m, so all are same size.
Joist are now installed, but I feel great support on supported joists and not as good but OK support on free spanning joists. The joists satisfy both strength and deflection criteria.
Is there any way to soften the difference in deflection ?
Any Practical suggestions would be appreciated.
RE: Deflection of Timber Floor Joist
1. I'd probably try to adjust the connection where the joist is bearing on the partition below. Perhaps notch out the top plate somehow.... to let the joists move freely as intended.
2. Bridging, at least the way I've done it, would tend to force adjacent joists to deflect similarly. In your case, since the problem joists are not deflecting enough, the bridging solution will tend to lift the adjacent joists, and that lift will add more load to the 'non-bearing' partitions... which may be a cure worse than the concern, which is something you'd have to evaluate.
3. Increasing the moment of Inertia to directly reduce the deflection of the 'ok' members can work too.
So Im using all the partitions as load bearing walls. The joists are spanning 6m where there is no support. Where there is support the joist span 4.5m continuous support.
Deflection in free spanning joists about 12mm i.e Span/480 which is considered to be acceptable.
When I walk on the floor I slightly feel the difference between where the joists are supported and where they span freely.
The joists at this time are not blocked (bridged) maybe this will help a bit.
Kootk's idea sounds good.
Just wonder if anyone else has come across this and what they have done about it if anything, because everything complies with standards.
1) Provide a deflection gap beneath the joists with walls below or;
2) Try to bridge the unsupported areas with supporting girders, even if those girders were designed to loose deflection requirements.
Differential stiffness / deflection is a common problem in wood: Link. At the end of the day, it doesn't much matter what criterion you designed to if you've got an unhappy owner.
Sometimes its not possible to provide supporting girders because of headroom considerations.
I think in this case either solid blocking between joists with screwed fastenings or doubling up girders (which can still be done) will surely help, like what you suggested.
Gave me an idea, which solves the problem.
Just came back from site meeting where it is possible to place a bearer under the existing 6m joists to reduce span to 4.7 like the other spans.
Great outcome and economical.
It is a supporting beam under the joists.
We also had a good walk around and jump around where the owner is about 110kg (Im about 75 kg) where remarked that the floor was as solid as a rock. Maybe it was my imagination but I felt a little difference in support between the 2 spans, he did not even though he weighed more than me. Still put supporting beam to reduce deflection since we have the opportunity.
"Bearer" is an Australian term for beam, mostly referring to wood beams in residential construction.
