EMD 12-645-E5
EMD 12-645-E5
TUGBILLMAIER
This for L4189, I enjoyed your reponse to CAPTKHAOS, I have a simular problem, I am the chief engineer on an old navy YTB tug, this one here was YTB-799. Like you explained to Khaos, the flow of the lube oil, I have the michiana filter pot. I recently had the two 20# relief valves rebuilt , Before the rebuild i had a lube oil pressure of 60 PSI, after the rebuild i now have a lube pressure of 38 psi. I called the company that rebuilt the valves and he told me thta one of the springs was bigger than the other in other one had a 20# spring and one must have been a 30 or 35 lb. This at fullspeed or 830 rpm. My lube oil temp is also high it is running at 208 deg where it ran at 197 to 200 deg. I am using mobil grad 410C lube oil. The soak back pump runs for 38 mintues after shut, it is where the navy had it set for, I talk to a EMD mechinac when I did a complete rebuild and he told me that is what EMD recmends. Any do you think I should change one of the relief valve prings to a heavier size.
RE: EMD 12-645-E5
Mike Halloran
Pembroke Pines, FL, USA
RE: EMD 12-645-E5
i HAVE BEEN WORKING WITH EMD TECH REP, BUT HE DOES NOT HAVE ANT INFORMATION ON THE VALVES , JUST TOLD ME THAT THE NORMAL PSI SHOULD BE 40 TO 70 PSI. THERE IS NOTHING IN THE MANUALS, IT HAS TO BE THAT ONE OF THE RELIEF VALVES HAD A LARGER SPRING IN. WILL SEND SOME PHOTOS AS SOON AS I LEARN HOW.
RE: EMD 12-645-E5
