low lube oil pressure EMD 12-645-E5
thread321-290487: EMD Low Oil Pressure
To CaptKhaos
I have the same problem now, I had an oil pressure of 60 psi befor I had my two 20# relief valves rebuilt, now my oil pressure is down to 38 psI. I called the people who rebuilt them and he told me that one valve had a bigger spring. I do not prelube every time only if the engine has been shut down for more than one hour. I have 14 filters in the filter pot. I am with the U.S.Army Corp Of Engineer's , the tug is one of the navys old YTB. This one was YTB-799. Do you have two 20# relief valves by the filter pot. One is for if the filter pot plugs up the oil will bypass the pot and the other one is for thelube oil cooler. I called EMD and they told me that the valves were an add on. And you should have a 40# relief valve in front of the engine. I would like to here more about your findings. this is tugbillmaier handle.
To CaptKhaos
RE: low lube oil pressure EMD 12-645-E5
