Maximum sizes and weights for Shell and Tube Heat Exchangers
Sirs,
What are maximum sizes and weights allowable for Shell and Tube Heat Exchangers? I was searched in TEMA standards and API 660, but I only read about 100" diameter restriction. I think that up to 50 Metric Ton bundle of tubes could be pulled, but are there any formal codes, norms or standards which restrict S&T fabrication?
Regards.
Eng. Orangel Roca
Inelectra S.A.C.A
Caracas, Venezuela
Regards.
Eng. Orangel Roca
Inelectra S.A.C.A
Caracas, Venezuela
RE: Maximum sizes and weights for Shell and Tube Heat Exchangers
The largest heat exchangers (power plant steam condensers) are built on site.
I have seen high pressure feedwater heaters built 60' long and 80" dia. The tube bundle was 20T, I didn't ask what the shell weighed.
There is no real performance gain from making them bigger. You are usually better off with two or three in parallel. And that way when one is down you can continue to run at some capacity.
http://www.heavyliftspecialist.com/video-picture-g...
A lot depends on the fabrication shop capabilities and the final site location......
MJCronin
Sr. Process Engineer
