Nastran Enforced Displacement
Hello All,
I am trying to enforce a small displacement on a thin cantilever beam in the horizontal direction, then apply another displacement in the vertical direction.
I was trying using subcases but the subcase manager only allows loads to be managed and not displacements. How can I apply the horizontal displacement, then take that result and apply the vertical displacement. Hopefully, this is a simple question for someone.
I am using NX 9.0.2.5
Thanks in advance!
Thanks in advance!
RE: Nastran Enforced Displacement
apply a unit load in each direct, scale to get the deflection you want, and add.
