Flame arrester
Flame arrester
Please give me some information of what is necessary to know when ordering a flame arrester?
Any answer is appreciated.
RE: Flame arrester
PIe Size, type of connector (flange, screw or welded), gas composition, pressure at that point and flow rate or velocity wouldn't go amiss
RE: Flame arrester
Design Pressure
Design Temperature
Material
Fluid description, viscosity, density etc.
Flow rate
Max allowed back pressure
Flange or otherwise end connection details
Any support arrangements required.
That should get you going.
RE: Flame arrester
Please advice, if its important that the flame arrester is ATEX certified?
Thank You again.
Best regards
RE: Flame arrester
RE: Flame arrester
RE: Flame arrester
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
