Remove face in Catia
General question: Is it a bad habit to use Remove Face in Catia, rather than using more efficient the other available design tools in Part Design?
Also, NX has a similar feature which is named Delete Face.
The big difference is that the NX Delete Face has a lot more options (please, see the attached file).
Does Catia have similar alternative, too?
USSagittarius
RE: Remove face in Catia
I usually only utilize the Remove Face command when I'm cleaning up a model from a dumb solid or some imported STEP file data. I don't use it when constructing a solid model in CATIA from scratch. Just my two cents...
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
USSagittarius
USSagittarius
USSagittarius
USSagittarius
USSagittarius
