Spline To Curve
Spline To Curve
I have a situation where I imported a DXF into UG NX 9.0. And, there are splines which I need to convert to basic circles. The method I use is create 3 points on the spline. Then, I create the circle through the 3 points. Is there a quick way to convert these splines?
RE: Spline To Curve
www.nxjournaling.com
RE: Spline To Curve
RE: Spline To Curve
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Spline To Curve
But, have you tried to set the import option import polylines as : Splines OR arcs / lines in the dxf import ?
Regards, Tomas
RE: Spline To Curve
