Getting point coordinates relative to WCS in NX Open
Hello everyone!
Obviously a very common problem, but I could not figure it out yet.
Using NX Open, I need to get coordinates of points relative to WCS.
In VB example I've seen a curious construct: NX.CoordinateSystem.MapAcsToWcs.
Does it exist for C#? I could not find it.
Or any other working method would be fine.
www.cadroad.com
RE: Getting point coordinates relative to WCS in NX Open
This is a function in the SNAP library -- it's full name is Snap.NX.CoordinateSystem.MapAcsToWcs.
It's documented in the SNAP Refernce Guide, and example code is given.
Note that there are two versions -- one for mapping points, and one for mapping vectors.
SNAP is just a .NET library, so you call any SNAP function from C# code.
