SA-249 N08367 stress values
Experts,
I cannot find stress values for SA-249 UNS N08367 in Section II Part D.
Am I just overlooking them or are they really not there?
I have found them for SB-676 UNS N08367.
Thanks in advance,
numberfive
RE: SA-249 N08367 stress values
There is no stress line for N08367 under SA 249.
This is an odball material that is classified as ferrous in some specs and non-ferrous in others.
So although SA-249 N08367 may be commercially available, you must use SB-676 (for example) for Sec VIII, Div 1.
Mike
SnTMan,
This is exactly what we have found.
The customer supplied tubes (for use in a Sec. VIII, Div. 1 vessel repair) are marked and supplied with an MTR as being dual rated SA-249 / SB-676 N08367.
We will proceed and document as SB-676.
numberfive
numberfive, if certified to SB-676, you're good to go...
Mike
