What type of welder should I purchase for 1/4 inch steel?
I have a 200 amp service pole where I live and would like to purchase a welder to repair welds on some farm equipment like the three point hitch bolts on the equipment. Thanks for any advice. Ive looked at the Lincon 225 AMP Stick Welder. Would this work and would my 200 amp service pole handle it?
RE: What type of welder should I purchase for 1/4 inch steel?
If you can spring a few bucks more, a wire feed would be the way to go, you should be able to pick up a good 200A wire feed for CAN$1500 ± and you'll find it a lot easier as well as more versatile....Mike
