Guy Wires Connected to API 650 Storage Tank Roof
The question has come up as to whether reinforcement pads are required when guy wires are connected to a API 650 storage tank roof via a lug. The lug is a vertical plate welded to the roof that has a hole in it for the guy wire.
I've looked at API 650 and it does not appear to address attachments like this on the roof. Does API 650 address this? IF so, where? Also, if I was to evaluate for the need of reinforcement, what would be the best approach? Please advise.
RE: Guy Wires Connected to API 650 Storage Tank Roof
Was there some kind of mistake in the original design of the tank ? Are the wires for wind loading ?
I suggest you consider using a standard pad-reinforced design for a pressure vessel lug
MJCronin
Sr. Process Engineer
I'm not aware of a good approach. You can treat a cone roof as a cylinder with radius equal to the normal radius of the roof, which will be very large for a low-slope roof. You can use the approximation that Bednar gives for line loads on a cylinder. The result will be very low allowable loading. If the roof is steeper or thicker, it will help. If you can run the guy lines to the top angle, you have more to work with. If you use struts instead of guy lines, you could run bracing between rafters to transfer loads to structure below (assuming there is structure below).
JStephen, thanks for your reply.
Consider gusset reinforcements of the angle for this connection.
MJCronin
