Continuous feature symbol
Is there a continuous feature symbol available in SW? If not, do you know if there is a balloon or border style built-in to place around the CF?
tia, Diego
RE: Continuous feature symbol
When you put in a note, under the "Text Format" section there is a small box with the centeline symbol and a green plus sign. Click on that. A similar option exist for dimensions.
Thanks djhurayt. Unfortunately the CF symbol is not there. The standard border for it is the same as the ST symbol, so I may look at editing that symbol replacing ST with CF.
Regards, Diego
I have it and don't think (??? ponder) I created it, I would look around, try under modifying symbols. But res the ST symbol is the same just change the text and save.
you can also just type
<MOD-CF>
in all CAPS in a dimension or note
I think this will create one for you and put it in you "modifying symbols" library for next time
