Port arrays do not work
I'm using NX 8.5 and am having the exact same problem with Port Arrays (Routing/Electrical) as icetea posted (see thread number below). I have not seen an answer to his post, or others like it. Can someone please explain why this is not working.
thread561-364416: Nx9 Electrical Routing and Qualify Part - anther Rou
RE: Port arrays do not work
Thanks for your query. I will let you know if i find something valuable.
Best Regards
Kapil
As of now the situation is like you mentioned so not big respite but i was handed over this environment variable by on of the experts which you can use for invoking the old Instance Feature dialog (please note that it might work till NX10).
NX_SHOW_LEGACY_INSTANCE_FEATURE=1
Once you set this variable you can find the old Instance Feature dialog at Menu > Insert > Associative Copy > Instance Feature
I hope this helps.
Best Regards
Kapil
