EXPERT NEEDED - Note spacing anomaly
Yes, I agree that the title sounds like this should be an easy question, but it has left me confused.
I have two notes, one from a migrated drawing from I-DEAS (migrated with CMM) and another one created inside NX. The issues is that when I insert a user defined symbol which has anchors in the dead center of the symbol it increases the spacing of the line above in the NX note but not the migrated note.
I have compared all the properties inside the notes and they are identical, I even checked the MPI & MPR arrays programmatically using the following journal.
Can someone please let me know how to make the NX note spacing look like the note from the migrated drawing?
http://files.engineering.com/getfile.aspx?folder=5...
http://files.engineering.com/getfile.aspx?folder=d...
Design Engineer, NX 8.5
CODE --> basic
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim theUI As UI = UI.GetUI()
Dim mpi(99) As Integer
Dim mpr(69) As Double
Dim radius_value As String = Nothing
Dim diameter_value As String = Nothing
Dim numObjects As Integer = theUI.SelectionManager.GetNumSelectedObjects()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Dimension")
For i As Integer = 0 To numObjects - 1
Dim nXObject1 As NXObject = theUI.SelectionManager.GetSelectedObject(i)
Try
theUFSession.Drf.AskObjectPreferences(nXObject1.Tag, mpi, mpr, _
radius_value, diameter_value)
Dim n As Integer = 0
Do
Echo("MPI " & n & ": " & mpi(n))
n+=1
Loop Until n = 100
Echo("")
n = 0
Do
Echo("MPR " & n & ": " & mpr(n))
n+=1
Loop Until n = 70
Catch eX As NXException
Echo(eX.ToString)
End Try
Next
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
End Sub
Sub Echo(input As String)
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
lw.Open()
lw.WriteLine(input)
End Sub Design Engineer, NX 8.5
