Pump Type Selection for Make up in the tank
All,
In one of the ongoing project for FPSO, We need to select a pump for Fresh Water Application. This pump will only be used when there is requirement to MakeUp (Top up) in overhead vessel, means service will be intermittent. Suction pressure is around 4 Barg, and differential pressure is 9 barg. Inlet connection will be from utility station of module.
Pump can be Electrical Motor or Air driven.
Now, Can anyone suggest me cheapest solution in terms of pump type (Except Centrifugal) which suits the requirement?
Look forward to have your suggestion.
RE: Pump Type Selection for Make up in the tank
